06-28-2010 12:22 PM
Alright, I will put together some hints for the swing up. I will explain some of the relationships between the cart and the pendulum that should help people come up with an algorithm. Probably will take a day or two to get them written.
Bruce
06-28-2010 12:55 PM - edited 06-28-2010 12:58 PM
I tried (1) Chrome, (2) IE8, and an (3) ftp client. In all cases, I get the same 12.7MB file which is not a valid application. 😞
I tried a few others, (simulation interface, PID, RT module) and the all download as the correct size.
Only the control design and simulation module downloads truncated. From the first byte on, the progress dialog says it's going to be 12.7MB.
06-29-2010 04:46 AM
Altenbach,
I found all the downloaders were precisely 132kB. When ran, I get this:
I've zipped up the downloader and attached it to this message, see if that works for you.
Note: To get around my virus checker, I've had to rename the .exe file as a .tar file before zipping it, so you'll have to unzip first, then rename the .tar as a .exe
I hope this is helpful?
06-29-2010 10:14 AM - edited 06-29-2010 10:15 AM
Thanks Thoric, this downloader seems to work so far (still downloading the toolkit....). 🙂
So whatever it is, the NI download site is seriously broken. I tried again today, and the toolkit was still truncated at 12.7MB. (I am running W7, 64bit)
06-29-2010 02:17 PM
OK, it seems the fixed the direct download link now too. 😄
07-01-2010 03:34 PM
07-01-2010 04:51 PM
HI everybody,
this is a test.
07-01-2010 05:17 PM
Hi everyone,
sorry for the previous post, but I am new on the forum.
I came across this challenge and I found it very interesting, althought I am new to LV so I don't think I will be able to develop anything serious.
I wrote before a quite long introduction but when I hit post the message, the forum server replyed that I took too much time to edit my previous post, and everything I wrote went lost.
I'll rewrite something later.....
That\s all by now, see you.
07-02-2010 09:58 PM - edited 07-02-2010 10:00 PM
I have a question for Mr Ammons.
I see in the specs you gave that the lenght of the pendulum is 0.78 m.
But in the pendulum animation (in the VI front panel) that shows the pendulum swinging, if I look at the X variable, it appears shorter, about 0.3 meters.
So, my question is: is the parameter X the real distance in meters or it should be multiplied by a factor ?
What about the other parameter w, Theta, V ?
Is the simulation referred to a generic system, that is not the real one ?
Thanks.
07-02-2010 10:24 PM
The length of the pendulum really is 0.78 m. I drew it a lot shorter in the simulation just to save space. The rest of the parameters are correct. The simulation matches the real system to the best of my ability.
Bruce
