CodeMeter or WIBU-KEY runtime system is not installed
I've got a labview program named "application.exe" and when I launch it, the error "CodeMeter or WIBU-KEY runtime system is not installed" appears.
I can launch Labview.exe, no problems...
Labview version installed: 11.00
Program application.exe created with Labview 8.6
Any ideas?
Thanks a lot
(20,038 Views)
Hi Greg,
Thank you for using the NI discussion forum.
Did you try to install the CodeMeter and WibuKey runtimes (http://www.wibu.com/en/downloads-user-software.html)?
It seems not to be a problem with LabVIEW, but with the software protection dongle used by your program.
Best regards.
(20,016 Views)
