07-18-2014 01:48 PM
Hello all!
Here is what I want to do. In the file attached, there is a cluster called " FROM THIS" and an array called " TO THIS"
Essentially, what I would want to do is somehow convert the cluster array to the normal array where I can save it using the VI I built.
If the cluster can be saved into a spreadsheet and used to imprt that into the excel file...then let it be.
The function of the clusters array should work perfectly as it is programmed. and the resulting array cluster should be saved into the excel file.
Please help me! Thank you !
07-18-2014 01:53 PM - edited 07-18-2014 01:54 PM
You already have another post on this topic. http://forums.ni.com/t5/LabVIEW/Clusters-to-Spreadsheet-Excel/td-p/2924938
Keep the discussion there.
Just because you don't get a VI handed to you in working order does not mean you should start yet another thread about the same thing.
07-18-2014 01:56 PM
Similar question yes, But i figured out how to do the saving technique. Just need to figure out this small problem. Care to help?
07-18-2014 01:59 PM
It is related to the same question. Keep it there.
And nope, I am not interested in doing someone's homework for them.
