08-03-2009 12:27 PM
Clusters look like they can be used to "future proof" what gets passed to a sub vi.
But they break too often, and are not flexible enough.
Is there a "software engineering" solution to making them more future proof?
How about using arrays inside of clusters?
Just skip clusters, and pass references?
What's the best solution?
Chris
08-03-2009 12:29 PM
Make your cluster a type def. It is an option under customizing a control.
Lynn
08-03-2009 01:18 PM
johnsold wrote:Make your cluster a type def. It is an option under customizing a control.
Lynn
And here is a Nugget to go with that topic.
Ben
08-03-2009 02:13 PM - edited 08-03-2009 02:13 PM
Thanks for the replies folks.
But do Type Def suffer the same problem that Globar variables do? They are hard wired to a file. Which means any subVi using can't be truly portable
with a group of programmers. (I use universal shift registers that are 100% portable, but they're weird).
08-03-2009 02:21 PM - edited 08-03-2009 02:23 PM
Chris in Colorado wrote:Thanks for the replies folks.
Message Edited by Chris in Colorado on 08-03-2009 02:13 PM
Define "Truly portable" Type-defs are a blessing when working ina group development environment. I shiver at the thought of doing group development with them.
Q: What is a "universal shift register" ?
Ben
PS Please concider marking Lynn's reply as the solution since he replied first. The best I would get is an "assist" (still in hockey land) You can un-mark my post as the soltion using the "options" located in the top right corner of that post.
08-03-2009 02:31 PM
USR are the trick where you use a shift register on a wire inside a while loop that runs once, but do NOT define the starting value.
The subVI retains the value between calls = hence a true global.
Great for Write-Once-Read-Many variables like Serial Number, IP address, etc.
08-03-2009 02:38 PM
OK now I see.
USR = Un-initialed Shift Register also known as Action Engine.
I use Type-defs with them as well (see the nugget linked above)
Ben
