07-08-2014 10:22 AM
I'm learning to work with LabView and I need some advice.
I'm trying to implement a VI where I can store some data in a list. My data is a mix of integer, string and boolean.
Is there a way to store clusters in a listbox?
Or any other advice how can I accomplish it?
Thank you
07-08-2014 10:42 AM
Fairly easy to go from an array of cluster to a 2D array of strings
07-08-2014 10:43 AM
Thank you
You can store data in a cluster.
What is the intent of using a listbox?
07-08-2014 10:50 AM
I need to display saved data. I push the button and my data are added to a table. There could be unlimited number of rows. So shift register isn't enough
07-08-2014 10:54 AM
Unlimited? Do you mean "N" number of rows?
Can you show how your saved data looks like? Jeff has already provided the answer as far cluster to Table in concerned.
07-08-2014 10:58 AM
I need it to look like that. Any ideas how to do it? I have tried for like 3 hours to do it.
07-08-2014 11:04 AM
Looks like an array of clusters.
07-08-2014 11:06 AM
yes, agree. but could you please tell me how to make it dynamic so it grows when I add new elements? And I couldn't find how to make a slider to scroll it.
07-08-2014 11:06 AM
Then attach a simple VI containing the control instead of a picture.
07-08-2014 11:07 AM
