Citadel database
Hi Everyone,
Is it possible to use a relational database with the vi's 'open trace', 'write trace', ...
If Yes, how can I do it?
(3,209 Views)
Hi Poema,
These calls are specifically intended for use with the Citadel database (which is itself a relational database) and so won't work with other instances of SQL.  The Citadel however can be used for other purposes so I find that it makes sense to install it with your LabVIEW environment.  I create other application specifc tables (IO configurations, user information etc.) in it, as well as using it for data logging.
Hope this answer helps.
(3,155 Views)
Thanks Sipic,
Is it possible to connect with the Citadel database via a DSN connection or another connectionstring?
(3,134 Views)
Yes, you can find details here.
Emre
Actor Framework rocks!
Emre TUZUNER
(3,125 Views)
Absolutley Poema,
I use a UDL connection string and pass the path of the UDL file to the LabVIEW 'open database connection' vi.
If you're not familiar with how to create a UDL sting you create a text file using 'Notepad' and then save the blank file with the extension .UDL.  This is then associated by Windows with OLE DB Core Services.  If you then open the file it opens a Data Link dialogue window that will allow you to select your SQL instance (the Citadel).  Remember to use 'Integrated NT Security' as your authentication mechanism.
Give that a try and see if it works for you.
(3,122 Views)
Oké, Thanks
For your information, I will use DBeaver to manage and consult the Citadel database
(3,093 Views)
