Circle Fit Example
Has anyone seen any good examples of fitting to a circle?
To make things clear:
Given a set of x,y points, return the centre and radius of a circle which best fits the data.
Many Thanks
Nick
(4,194 Views)
Accepted by topic author niNickC
There's a VI called "Fitting on a Sphere VI" that can do what you want. You just need to use a value of zero for Z data points.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(4,187 Views)
Did you do a Web search?  A number of algorithms are out there -- pick one that seems appropriate for your data set.
(4,185 Views)
Yea I did spot this and tried exactly what you said with no success. Then I looked again and realised I messed up. (Forgot about the displayed precision!)
.. yeah ...
Thanks though!
Nick
(4,169 Views)
http://lmgtfy.com/?q=circle+fit+algorithms
Yea just trying to save some dev time!
Nick
(4,167 Views)
Since you are interested in a LabVIEW solution, a forum search here would have immediately found many example of James's suggestion above.
For example look here
(4,108 Views)
