01-24-2014 04:01 AM
We are running a CIN program since years. Now we switched from WIN NP to Windows7, from Labview 7.1 to Labview 20110 and from VC++ 6.0 to VC++ 2012. The Codes is compiled and is running. But I am not able to run it in debug mode any more. When the program hits the _asm int 3 the code crashes and Labview aborted without any message.
Does somebody has any idea what to do?
01-24-2014 08:53 AM
You followed the points listed here?
I just wanted to add that afaik (haven't found any contradicting information) LV 2010 is the last version with official CIN (Code Interface Node) support. Later versions removed CIN from the palette (as well as documentation on it).
In order to maintain compatibility with older VI code, later versions can import CINs, but i am not sure if/when there is an official EOL of this feature.....
Norbert
