07-11-2014 05:56 AM
OK, now I am getting into Pit Bull mode. I am going to wrestle this thing to ground if it kills me. My vi currently goes to the NewFileName page first to create the file. There I clear the array for all three plots. I then get the computer clock and feed that into a property node for 'X min'. I add 14400 seconds to that and connect that to a property node for 'X max'. This will give me a viewing window of 4 hours. Much better for discerning what is going on in the first 10 to 30 minutes than looking at a 24 hours viewing window. The vi will still fill the file for 24 hours and then close it and start a new file. So, having done the above, I am now looking at a graph with 6 PM instead of 6 AM! I am getting the 4 hour difference across the X axis (YEA!!!!), but it goes backwards to an earlier time. I suspect I need to change the X min and X max? Finally, and this is the most perplexing, the date is 17/01/70. I have an time indicator block that is reading the computer time and date and that is right on the money.
Ron
07-11-2014 10:09 AM
I have finally taken some time to test out the suggestion/solutions. I am looking to create a chart with 24 data points, one for each hour, and then following the 24th point just before posting the 25th value clear the history and start the chart over at hour one, with the current date and time of the first hour. I would like the x-axis to show 24 incriments but it seems to only "book end" the chart.
07-11-2014 01:27 PM
Final version - Upon vi initialization the starting time and date and put it in a string indicator at the top left corner of the waveform chart. Read the present time and date while the acquisition is running and put it in another string indicator at the top right corner of the waveform chart. NI, you win, I give up.,
07-12-2014 09:54 AM
I going to attempt to put all the suggestions in the thread that pertain to the original question in one post. Please refer back to the posts to provide kudos to those who have assisted in solving the problem.
The solution to my problem should be to set the Multiplier to 3600, plot a value every one hour. The wait function set to 3600000 ms. Wire the min value to the Get/date/time function conversion DBL, set the max constant value to 86,400 (24 hours) . Show only major tick marks on the x-axis. Set the chart to scope, or wire a shift register to add +1, once the value reaches 24 then trigger a true/false to clear the chart or re-initialize the vi to default values.
07-13-2014 08:52 AM
FWIW: I wrote an article about this a few years ago
Blog for (mostly LabVIEW) programmers: Tips And Tricks
