07-25-2017 03:00 PM
I'm trying to write on/off to 3 lines instead of just 1(which worked perfectly) but the program either throws an error that I have only 1 channel and 3 data or 3 data and 1 channel. If I have the true/false arrays as having entries, it complains that there is only 1 channel and 3 data. If I have the true/false with 1 entry it complains I don't have enough data lines.
Solved! Go to Solution.
07-25-2017 03:11 PM - edited 07-25-2017 03:12 PM
I'm not sure on the array of booleans and how that relates to physical channels and lines. I've always used U8s for digital controls. I've made that modification and it runs correctly on a simulated NI6221.
So basically instead of using 3 booleans in an array, pass an array with a single U8 in it with the numeric equivalent of your position. This would be 0 or 7 for what you are trying to do.
Best,
Tim
