02-22-2017 06:57 AM - edited 02-22-2017 07:02 AM
I want to supply an external file to "Write to measurement file" block. But, I want to change the name of the file every time I am in a case/loop. Is there any function which can do this programmatically taking regex or otherwise?
Or should I pass an array of names and select one each time?
02-22-2017 07:02 AM
Hi JohnDoe,
there is a palette full of file functions called "File functions": In there you also find functions to split and join parts of file paths.
And there is a palette full of string functions (I guess you know their name): here you will find several functions to manipulate strings…
LabVIEW is a programming language. All you need to do is "programming"…
