Change resolution image in a Basler camera snap mode.
First of all thanks a lot for reading this post and being able to help.
I have noticed the next problem:
My application has a camera, this camera takes images (snap mode) and application process them (detect some edges in the image). It works fine.
But when I make the Display bigger my application takes longer to process images (and for me that is crucial). I think that this happens because my application in this case has to process a bigger image (bigger display = bigger image??) So maybe if My camera takes images with lower resolution I solve the problem.
So how can I change image resolution captured by my gigE camera? In NI MAX or in Labview?
Thanks a lot!
(3,067 Views)
You can change the acquisition window height and width in MAX or using property nodes to change the resolution of acquisition.
uday
(3,033 Views)
