08-15-2016 11:08 AM
I need a program that takes a simple element, let's say a square of some sort, and change its color depending on some text input, in this case it demonstrates the temperature (so if the temperature is between 19 and 21°C, the color should be a pale green, below that it should go from pale blue to rich blue, and above that from pale red to rich red). The problem is that I'm a bloody beginner with LabVIEW, as in the only programm I have ever done is a "walking light" (think Knight Rider car), which worked but was badly done. I would be happy if any of you could point me in a direction on what to look for, because I'm really clueless. Thanks in advance
08-15-2016 11:13 AM
You haven't given enough information. Specifically, what is this "simple element" you are talking about?
Is it an object in a 3D view? Part of a 2D image? A decoration on the front panel?
08-15-2016 11:58 AM
A simple 2D decoration on the front panel, just a quadratic shape on which the color change will be visualized. A colorbox would be an option in this case I guess?
08-15-2016 12:55 PM - edited 08-15-2016 12:56 PM
Yes, colorbox is good choice to display a number of different colors.
Then you need to map your values into colors.
Make array of input value bounds - when it should change color and array of corresponding colors (basic color table), then threshold 1D array function will allow to map them.
For continuous change of color it can be formula mapping input range to colors (R, G, B separately) or lookup color table interpolation
08-15-2016 01:50 PM
