07-11-2013 07:09 AM
I need to change the UI language for MAX (Measurement and Automation Explorer) and I found this discussion and this product suggestion.
I verified that the language can be changed modifying some parameters in Control Panel » Regional and Language Options.
The problem is that I'm in a situation where these settings can't be modified:
I have Win 7 Enterprise, where I can change the language of the OS based on the user is logged into the machine, and this is good.
I think that MAX language should be set:
07-16-2013 07:53 AM
Dear vix,
The only way to change the language of MAX is to change the OS's regional settings.
Have a look to the following KB on the topic:
Changing the Language of Measurement & Automation Explorer
http://digital.ni.com/public.nsf/allkb/9893C1767C93D20E86256F49001CDA92?OpenDocument
Enrico
09-24-2014 03:40 AM
Hello Enrico,
the link in your email refers to a page with the message
Error - You are not authorized to view this document
Could you check, please?
04-20-2018 04:04 AM
The only available way is to change the language in the Regional and Language Options.
Under Regional Options, simply change the Standards and Formats setting from Japanese/German/French to English and click Apply.
The changes should take effect the next time you open Measurement & Automation Explorer, without having to restart your computer.
04-20-2018 04:07 AM
You can read in my first message that changing Regional Options is not an option in my case.
This is the reason why I asked for a different way to get the result.
07-02-2019 12:11 AM
Go to windows search Bar and type region settings and Change the region launguage over there.
