Change RS232 Port Settings in the Win 7 Device Manager from LabVIEW
Is it possible to change the Windows7 COM port settings in the Device Manager from LabVIEW?
I just need to be able to change the basic parameters such as baud rate, data bits, parity, stop bits, etc.
(2,522 Views)
Hi Red Sox Fanatic,
You can use MAX to do that. If you go to Devices and Interfaces » Serial & Parallel. I couldn't find a way to do the same in LabVIEW, but you can use  VISA property node to modify the parameters of a VISA session you will run in LabVIEW, however. This KB How Can I Programmatically Check My Serial Baud Rate in LabVIEW?  should help you.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(2,505 Views)
