Change IP address to sbRIO
Is it possible to change IP address for NI-sbRIO9606 in labview code?
I am using LV2012.
(3,042 Views)
Real-Time>>Utilities>>RT Apply Target Network Setting.vi
(3,032 Views)
I don't have that vi in my functions.
(3,023 Views)
You need to install LabVIEW realtime.
(3,015 Views)
You could also try configuring remote target using network browser, https://decibel.ni.com/content/docs/DOC-12773.
(2,989 Views)
I have realtime module installed.
Using browser is not an option, I need to change ip address programmatically.
(2,949 Views)
JuhoR,
You can also use the System Configuration API to change the IP Address. I would recommend taking a look at the this example. It looks like they are doing something similar to what you are looking for. You can also change the IP address by accessing the sbRIO through FTP and modifying the NI-RT.ini file. The bottom half of the KB walks through that process.
Best,
Tannerite
(2,938 Views)
