10-31-2014 07:55 AM
Thanks for suggestion
There are 9 bytes which mean they are 72 commands. If I did it your way I will only be able to do one command per bytes. What happen if one byte has two high bits? Like if byte 2 (element 1) has two high bits
10-31-2014 08:43 AM - edited 10-31-2014 08:46 AM
That's what my post above attempts to address.
10-31-2014 11:18 AM
sticyfinger wrote:There are 9 bytes which mean they are 72 commands. If I did it your way I will only be able to do one command per bytes. What happen if one byte has two high bits? Like if byte 2 (element 1) has two high bits
You can easily create a boolean array with 72 elements using some trivial modifications and do exactly want I described.
11-03-2014 10:43 AM
I used a combination of Altenbach and Jcardmody (jim) suggestions.
Thanks.
11-05-2014 01:35 PM
Thanks.
You know what would really show your appreciation to these guys? Giving them kudos for taking the time to help you. Checkout this link and the When you get the help you want section.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
