06-03-2013 05:43 AM
I want to capture the entire panel image consisting of 4 channels output of the Agilent 6000 series scope (MSO7054B) when the output of the 1st channel goes low..Also, once this is done, I want to repeat the same process. Any suggestions on how this can be done?
Thanks in advance
06-03-2013 08:50 AM
06-03-2013 09:14 AM
@Wayne.C wrote:
mnx,
I'd start by reading the Programming and Syntax Guide so I understood what commands were available. Next I'd go get the NI driver.
One very important question. How often do you expect triggers to happen?
I would add to this that you should figure out how to do it manually, also. Combine that knowledge with what Wayne recommended and you should have a good start! 🙂
06-03-2013 09:29 AM
I haven't used the Agilent scopes, but I suspect they are similar enough to the Tektronix scopes. Pretty much every option you can manipulate manually, there will be a command you can send over GPIB/Ethernet/RS-232/USB. Have you decided on a communication bus? That would actually be the first step. Then manually try to figure out the settings you need to get what you desire, and then write a LabVIEW program (using the drivers given earlier) to repeat your manual process.
