Capture Signal in Simulink and Use it in LabVIEW
Is there an effective way of capturing a signal wave in Simulink and use it as an input to a transfer function in LabVIEW?
(2,509 Views)
Have you seen the information here: http://zone.ni.com/devzone/cda/tut/p/id/3057 ?
-Zach
(2,477 Views)
yeap but how could I use the signal transfered to be use to a transfer function?
to use a transfer function, you need a control a simulation loop. how would you connect the signal in SIT to the transfer function? and how about the synchronism of the signal.
at the moment Im using a global variable and add another while loop where I insert the control and simulation loop with the transfer function in it.
but, my problem is I could not make the signal to run synchrounizely in time as in Simulink. If in Simulink the signal run for 10s.. in LabVIEW, the signal waveform still look the same but the time is way off by hundreds, how could I synchronize the time value to be the same (ie. 10s)?
(2,467 Views)
SIT will take data from LabVIEW and pass it to a .mdl file running in another language using the SIT server.  This sounds like the opposite of what you are doing.
It this correct?
Justin Parker
Product Support Engineer
(2,433 Views)
