10-01-2013 10:58 AM
I have a 3rd party .Net assembly built against .Net 3.5 (CLR v 2.0.50727). I was able to load the assembly in LV 2012, but I can't seem to link to it in LV 2013. I've tried creating a LabVIEW.exe.config file as specified in the LabVIEW help to no avail. When I try browsing to the assembly in LabVIEW, I just get the message "An error occurred trying to load the assembly." Anyone have any suggestions on things to try or ways of diagnosing the problem?
10-02-2013 06:27 PM
Hey, codeman
I'll take a look into your issue with the .NET assembly shortly. If I find anything or have any questions for you I'll post back as soon as I can.
Ryan
10-03-2013 05:31 PM
Codeman,
I've done a little research into your issue with using your 3.5 .NET assembly in LabVIEW 2013. You mentioned making a LabVIEW.exe.config file which I assume you found in this Knowledge Base article: http://digital.ni.com/public.nsf/allkb/4742EB60B64BE22186257BCE0053B8FD?OpenDocument
It's important to remember that name and location are very important when loading a .NET library. If after following that KB article you are still having an issue you might try creating a config file for the specific project that will be using the assembly. Check out this article which is similar to the other: http://zone.ni.com/reference/en-XX/help/371361K-01/lvconcepts/config_net_app/
Beyond that it's possible your 3.5 assembly doesn't handle being promoted to 4.0 assembly very well by LabVIEW 2013. While that's unlikely, there is a way to tell LabVIEW to load the assembly as a specific version using Contrsuctor Nodes. An atricle detailing this process can be found here: http://zone.ni.com/reference/en-XX/help/371361K-01/lvhowto/net_specifying_assembly_version/
Finally, a good article detailing how an assembly is loaded when reference can be found here: http://zone.ni.com/reference/en-XX/help/371361K-01/lvconcepts/loading_assemblies/
3.5 and 4.0 assemblies use a different Common Language Runtime (CLR 2 vs CLR 4) and that could possibly affect the loading procedure which is why you see it work in 2012 vs. 2013. I recommend taking a look into the Knowledge Base articles if you haven't already, and feel free to include any other information about your assembly. I hope some of this information helps.
10-04-2013 08:43 AM
The first KB seems to have done the trick. I'm on Win 7. Apparently after downloading the assemblies from a cloud share, it was necessary for me to "Unblock" the assembly dlls on my local system. Gotta love these new security features. Thanks Ryan.
10-04-2013 11:01 AM
Glad I could help!
