11-09-2016 07:38 AM
Good afternoon,
I'm trying to make the CanOpen communication protocol between IXXAT - USB-to-CAN device and labview. So, I'm having problems defining the master / slave nodes, NMT, SDO, PDO, ... Does anyone know how to define this in a simple way in labview?
I have seen that people use the following library: http://sine.ni.com/nips/cds/view/p/lang/en/nid/202614, but is this library generic? Can I use it with IXXAT USB-to-CAN?
Is there any other way? Does anyone have an example?
Thank you very much for your help,
Iñaki
Solved! Go to Solution.
11-09-2016 07:50 AM
I believe the NI CAN Open library only works with NI series 2 (old) devices. I've had my eye on
http://sine.ni.com/nips/cds/view/p/lang/en/nid/214110
this add-on but haven't had a chance to try it out yet.
11-09-2016 09:03 AM - edited 11-09-2016 09:04 AM
Hi
This will not work
you will have to download VCI driver from the IXXAT homepage.
Maybe they have there a LabView Library for CanOpen.
Or you should do a call to them and ask for support
If not you have to do it in LabView by using the LabView CVI driver
Regards
juergen
