09-11-2006 04:02 PM
09-11-2006 04:10 PM
In most cases if you have the source code an upgrade is very easy. It sounds like you have an easy application but you should consult your local field rep to make sure.
Good Luck!
09-11-2006 04:24 PM
09-11-2006 04:28 PM
The most likely source of trouble would be the serial connection. In the past, LV used serial functions which had a blue wire identifying the port as an input. At some point, it started using VISA functions instead and, while I assume the legacy VIs are still there in 8.2 (they now have VISA code under the hood), they might not be or they might be removed at some future date and they probably don't help the performance. Depending on the way the app is built, it might be complicated to do some proper replacing.
Anyway, if your code used VISA back then, then you shouldn't have a problem.
09-11-2006 04:42 PM
Thanks for the quick replies.
As far as the source code goes, I'm not sure if we have a copy of it available. I inherited this issue from the previous product manager and I'm trying to get this all figured out. I'm not too familiar with the programming aspect of the software.
So is the copy of Labview we were using customized for our instrument, or is it an application which is compatible with any instrument which outputs a stream of data?
Again thanks for your help.
09-11-2006 05:13 PM
09-11-2006 05:14 PM
No source code = Start over again
Without the source code you will have to start all over again. Look for files with a *.vi extension because there are the source files.
LabVIEW is a general application for software development so LabVIEW is not customized but the source code makes it the custom application that communicates with the instruments.
