I wish to expand and collapse the bounds of a cluster control using one or two buttons to reveal/hide additional information in the control. Unfortunately, the Bounds property of a cluster control appears to be read only. "Change to Write" on the pop-up menu is grayed and disabled. Is there a way to enable changing of the Bounds property on a cluster and another way to accomplish this?
I don't like the thought of using a sub-panel to achieve something similar.
Set the cluster to "size to fit" and make supplemental elements visible/invible when needed. The cluster bounds will adjust to fit the visible elements.
Thank you tst and Jean-Pierre for the responses! At first glance I thought the suggestions had some limitations until I realized that "supplemental elements" could include inconspicuous transparent frame decorations. That led to the elegant solution which I demonstrate in the attached vi.
