01-15-2013 06:50 AM
I have built a datalogging application that saves data to a filename of name = current date/time on USB drive. This works fine when connected via network to the development computer, however, when deployed as a startup VI, the date and time section of the filename are missing, as if it can't read the RTC. The file creation time parameter of the file is correct.
any suggestions ?
thanks.
Solved! Go to Solution.
01-15-2013 07:07 AM
Hi can you show us the relevant portion of your code?
Marco
01-15-2013 01:53 PM
Here it is.
...can't recall why I write the indicator and set it's value by variable- the dangers of not documenting as one goes...
01-15-2013 07:17 PM
Think I have found it. When deployed, the front panel indicator ceases to exist.
http://digital.ni.com/public.nsf/allkb/FC5024A5DD6344C886256C8C0054689B
01-18-2013 03:04 AM
Hi JPP,
if you want you can mark the issue as solved (by yourself 😉 )
