05-03-2017 04:36 PM
Hey my labVIEW doesn't work anymore and i can't open my project can sombody please open my project and take some screenshots so i can explain my code in my worktask
Thank you in advance,
Seppe Pairon.
05-03-2017 06:04 PM - edited 05-03-2017 06:05 PM
Yikes. I have a feeling your problem is the VI is using too much block diagram space. You need to learn to use a State Machine and a Producer/Consumer. Your abuse of local variables will cause problems. Using a queue to pass the data to your second loop will help clean a lot of that up, make it easier to figure out, and easier to debug.
05-03-2017 06:53 PM
can sombody take smaller screenshots and higher quality it is for my script for school.
05-03-2017 09:55 PM
Attached a PDF printout that is probably the best thing you are going to get.
And I see that you have made some tidying efforts from the previous version but made no real substantive changes since this thread.
Good luck with the review.
