06-04-2013 08:54 AM
Strange - 1 is ASCII 49, or 00110001, which of course looks nothing like 64, or 01000000. You wouldn't have access to an o-scope to look at the raw signal would you? It would also help troubleshoot if you sent more than 1 character. Have you modified your code to have it grab all bytes at the port until you press STOP (or tried using my code)? Your message from 4:48 PM yesterday (my time) showed 108 bytes at the port.
06-04-2013 09:06 AM - edited 06-04-2013 09:07 AM
I have the communication working now. Thank you very much for your help Erik!!
I just reprogrammed the chip to send a series of bytes counting up to 10 repeatadly and their values display accurately in the byte array (formatted for 8 bit unsigned ints)
11-17-2014 11:41 PM
Hi,ipatka,
Hope this is available.
can i get the finnal code you made, because i am doing something similar but got issue? When i read from device, the get-queue-status return 0 biyes. i am very new to lv, so would you share your code? Thanks very much.
