Can't control the X-scales and plot data on a chart or graph at same time??
Dear friends,
I got a problem by reading the right timestamps from a datalog file (with timestamps and data) into a chart or Graph or XY-BuildGraph , at the same time.
I tried several solutions and believe me, its not working.  In the Properties for the graphs and charts..., I am controling the x-scales from the  ''scales'' and ''format and precision''. and autoscale is disabled. I need the timestamp to be showed in factional time precision, and there i tried to use in the properties for The charts and graphs, the "absolute time"  and changing the '' digits.
There are no problem scaling the right x-scales as i wan't (except tha right date), but when done, the datavalues are not plottet, and when it happens that the data are plotted, the x-scales changes to someting else not needed. A third problem is that the date is still set to the first global date (0101-1904) ???
I'll appreciate the a helping hand from all.
Regards
Zamzam
HFZ
Message 1 of 1
(2,015 Views)
