03-03-2015 03:57 AM
Hello everyone,
I am very new to LabVIEW and I am having a problem I can't solve on my own. I am trying to connect to a device via TCP/IP. Right now, it is just a printer hooked up the company network to test how this works (we'll get an upgrade for manufacturing equipment quite soon and I don't want to completly embarass myself when the technicians come here ).
However, when I open NI MAX and right-click on "Devices and Interfaces" the "Create new" prompt doesn't appear. I feel kind of stupid to ask this question, but does anyone know how to solve this problem?
Thank you!
Qbach
03-03-2015 04:22 AM
You don't need to add them.
Networking is done on any available device - you generally don't specify a network interface when listening/opening/reading/writing to/from the network and the OS deals with which networking adapter actually transmits/receives the data.
You just specify a target IP address and the OS/Network will find a route to it if it can on any available adapter (e.g. Ethernet/Wifi etc.).
03-03-2015 05:49 AM
03-03-2015 05:57 AM
Ah right - yes I guess you're right about "Ethernet Instruments" such as benchtop instruments you connect to TCP/IP with VISA. I had assumed he meant network devices as in hardware network devices such as your ethernet/Wifi adapter and it kind of sounded like he was doing native TCP/IP communications rather than using VISA instruments.
Apologies for the confusion!
03-03-2015 06:11 AM
Dennis,
I have NI VISA installed, as you can see in the attached image.
Is it maybe a problem with the missing/not functioning devices in the device manager?
Sam, absolutley no problem. As I mentioned, I am new to LabVIEW and don't now how to specify my problems without confusing anyone 😉
03-03-2015 06:34 AM
I updated all drivers, still doesn't work...
03-03-2015 08:06 AM
03-03-2015 09:03 AM
It's german. And it says "network devices". It appears or disappears when you select "local" or "local and network" under my system where it says something like "internet access to system configuration". However, this does not influence the ability add or create a new device in NI MAX.
03-03-2015 09:34 AM
03-04-2015 01:56 AM
Hi Dennis,
I did what I should have done first, I guess. I reinstalled VISA and now it works.
At least it's working. Thanks for your comments!
