Reply
Can't Connect to Network Stream in startup.rtexe
I have encountered a rather frustrating issue. I have developed an architecture that depends on network streams to connect my RT application (hosted on a cRIO) to several windows clients. Everything worked seamlessly when I was running the RT Host VI from my Labview project. However, when I tried to deploy the RT application as a startup vi on the cRIO (as startup.rtexe). I could no longer establish a connection to the nettwork streams.
I have tried adjusting the context name of the network stream path to "startup.rtexe", but this did not help.
Can anybody help me?
THANKS!
Message 1 of 4 (339 Views)
Reply
Re: Can't Connect to Network Stream in startup.rtexe
Hi RyanEwart,
Do you get some error code or a error message?
Carmen C.
Message 2 of 4 (305 Views)
Reply
I've been meaning to post my results. The error actually entered the chain prior to the Network Streams. It boiled down to a rookie mistake:
Don't use 'Value' Property nodes in a real-time application! When the RT application is deployed, no front panel is loaded and these type of property nodes will error.
Thanks!
Message 3 of 4 (301 Views)
Reply
Hi RyanEwart,
I'm glad to hear that this is already solved!
Best,
Carmen C.
Message 4 of 4 (298 Views)
Reply
