12-05-2013 02:06 PM
Can someone help me with these problems.
1. I have some code that plots a circle, triangle and a rectangle. I need the code to plot the three shapes onto the same graphs but can't seem to get it to work. The code is below if anyone wants to have a look and see if they can fix it.
2. The second but of code attached was advised by somone earlier on how to plot coordinates on a graph using a mouse but i can't get it to wire up properly. If you could have a look and get back to me it would be massively appretiated.
12-05-2013 03:33 PM
Anyone got any ideas? or currently trying something?
12-05-2013 03:37 PM
The problem with the mouse click example is simple - you are using the incorrect event. Don't use the timeout event when you want to detect a mouse event.
12-05-2013 03:42 PM
how do you change that? could you show me what it should look like please?
12-05-2013 03:42 PM
Recneps,
You already have individual threads running on both these topics. Please don't open multiple threads for the same question. You can always post a 'bump' in a thread to keep it visible.
12-05-2013 08:42 PM
