Can someone help me with a simple alarm clock
Hello
Well, I tried to think about your problem, but I'm kind of busy today (deadline coming up...)
I made a fast google search and found this: http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/opening_subvi_front_panels/
However, I'm almost sure that you'll need more help...
If this doesn't help you at all, try openning a new thread. I'm sure the guys will help you.
Have a nice day 🙂
Mondoni
Message 11 of 18
(1,441 Views)
Hi, it helps!
Based on the link given by you, I managed to call the sub VI and open up its front panel. Also, when I tried to stop the sub VI, it is working. but the only issue is the sub VI window doesn't close even though i have configured this option.
I understand that I need to carry out another step - "build a connector pane". This is where I'm stuck despite trying to follow the instructions in the help file on building a connector pane.
Message 12 of 18
(1,423 Views)
So sorry. I managed to find a close VI control that can solve the problem. :smileyhappy:
Message 13 of 18
(1,418 Views)
So your problem has been solved?
I'm glad the link helped!
Mondoni
Message 14 of 18
(1,401 Views)
i couldn open in my labview as it is 2009 version. can u pl send me in that version
Message 15 of 18
(1,340 Views)
Please read the entire thread. As already noted, you should use the version conversion board.
Message 16 of 18
(1,328 Views)
Message 17 of 18
(824 Views)
see here
Message 18 of 18
(802 Views)
