01-28-2016 04:28 AM - edited 01-28-2016 04:29 AM
I am trying to control some digital outputs on a 9474 module and a and a cRIO-9022 Chassis.
I was trying to drag and drop the module outputs in the FPGA section of the project onto a real time block diagram, but the output doesn't seem to be valid.
Can I only control digital outputs via FPGA VIs?
I didn't want to wait 20 minutes for the FPGA to compile so that is why I wanted to use real time.
Just wondered if there was any way to directly control the digital module outputs from real-time VIs.
01-28-2016
04:30 AM
- last edited on
12-02-2021
02:39 PM
by
NI_Community_Su
Hi David,
did you configure your project/cRIO to use the ScanEngine?
If you would you could control those DO channels using (kind of) shared variables provided by the ScanEngine…
Hint: search for "crio scan engine" to find relevant articles provided by NI…
01-28-2016 04:43 AM
All of the C Series modules are connected to the FPGA chip, which is why you must use the FPGA to communicate with them. When moving to FPGA, it is generally better to try and design your FPGA VI first so that you can minimise the number of compilations you need to do - some of the simulation tools can help with testing your FPGA VI before you need to compile it.
Or, as GerdW has mentioned - you can use the Scan Engine (or hybrid mode which allows some modules to use FPGA and some modules to use Scan Engine) which is basically puts some pre-compiled code onto the FPGA which takes the input/outputs of the C Series modules and puts them into shared variables which you can then read in RT. The downside is that it is much slower than using an FPGA VI and you cannot implement any custom logic without the FPGA.
02-02-2016 08:18 AM
Just a follow up question on this, will DAQmx code work on a cRIO if I use it in real-time mode? Or does real-time have a DAQmx equivilent? I have found the way I program FPGAs to be quite different to the way cDAQs are coded.
The difference with PWM modulation on a cDAQ and FPGA were quite big. Despite FPGAs being supposedly a lot quicker, I found I couldn't get 2,000Hz PWM with FPGA using a delay and shift registers (the recommended way) but could easily get 2,000Hz with a cDAQ using the DAQmx method recommended.
I am using the same module in both instances, a digital module 9474 using the CTR output for PWM. I wondered if there is a way to use this witha cRIO rather than trying to hardcode a PWM into the FPGA.
02-02-2016
08:28 AM
- last edited on
12-02-2021
02:40 PM
by
NI_Community_Su
Hi David,
No.
No, not really.
You have a ScanEngine instead.
Yes.
Then you made something wrong…
02-02-2016 08:54 AM
2kHz. For some reason it starts to look really deformed on the oscilloscope at anything over 500Hz. I was surprised as I always thought FPGAs could perform a lot better than cDAQs. Yet my cDAQ can give me 2kHz PWM no problem using the DAQmx feature with the ctr output. I wasn't sure if the digital modules have a built in PWM that I could also use with a cRIO rathre than coding one in.
PWM is fairly simple to code so I dont know why it doesn't work. I dont even have a varied duty cycle, its literally just delaying a while loop ever n seconds and alternating between 1 and 0 using an inverter and shift register. I can't see how I coudl have coded this to work up to 500Hz but then start to deform.
02-02-2016
09:20 AM
- last edited on
12-02-2021
02:40 PM
by
NI_Community_Su
Hi David,
We neither as you don't attach any code here…
I don't have problems to create PWM signals with 10µs resolution using a 9403 module!
02-02-2016 09:33 AM
