Can partial transparency of a tab control be achieved?
I want to place it behind another control with focus to draw attention to it by brining in semi-transparent tab control.
I want the semi-transparent control to fill the entire area of the front panel (not the entire screen like the LAVA fade-in VI), anyway it should be a control not a VI because the control with focus is another control and not a dialog box.
Thanks.
Message 1 of 10
(3,459 Views)
Well the only suggestion a couple of ways but it turns out neither worked.
First I was going to say use a subpanel, and insert into the subpanel a VI that is semi-transparent.  Turns out transparency is ignored in a supanel.
Okay no problem Windows supports Child Parent window relationship.  So make the child semi transparent then make the Main VI a parent of the child subVI.  That causes the child subVI to disappear.  It works fine if it isn't set to be transparent.
I guess a last resort that would work, but would suck if nothing else works, is use the picture control, and make an image of your tab that can be interacted with like a tab.  Sorry.
Message 2 of 10
(3,432 Views)
Please if it is posible give more detailed information about solution, I am interested too. i have some problem and can not solve. if it is possible please example VI post too. or pictures.
With best Regards
Hrachya
Certified LabVIEW Architect (CLA)
Message 3 of 10
(3,190 Views)
...you are a CLA, what have you tried?  Explain in detail what you want to achive and how you want it to look.  In the end a picture control can give you want you want, but lots of extra work.  Also you misspelled LabVIEW.
Message 4 of 10
(3,187 Views)
For First, I have not any misspelled in LabView.
For Second Yes I am an CLA....
I want to know Your experience for doing partial transparency of a tab. I do the same what You write without child and mother part. can not do that part.
Thank You
With Best Regards
Hrachya
Message 5 of 10
(3,176 Views)
Thank You
i find the solution for that task.
Thank You.
With Best Regards
Message 6 of 10
(3,172 Views)
@Hrachya wrote:
Thank You
Thank You.
With Best Regards
Oh well how nice for you.  Care to share it with the community, I'm sure the battler. would be interested in hearing what you did.
I highly suggest you spell the language you are an architect in correctly.  I have seen resumes thrown in the trash for not spelling it correctly.
Message 7 of 10
(3,164 Views)
I would suggest making the tab completely transparent and placing a semi-transparent PNG in it and moving it to the back. As for how to create a PNG with transparency, I'll leave it to you to look it up.
___________________
Try to take over the world!
Message 8 of 10
(3,153 Views)
Hrachya
In your signature .......
Message 9 of 10
(3,139 Views)
Like this 🙂
Thx
Message 10 of 10
(3,107 Views)
