Can no longer pin recent project to Windows 10 Taskbar (LabVIEW 2013)
In Win 8.1, I could pin .lvproj files to my LabVIEW taskbar icon, so when I right clicked, I could select my most important work. I have since upgraded to Win10 and now I can only pin recent VI's, and not the project itself:
Has anyone had this problem and found a solution?
(2,209 Views)
I can't really say.  I run several different versions of LabVIEW so I avoid this kind of opening at all costs.  (The project/vi will open with the last version of LV that you used.)  Instead, I just pin them to the LV Getting Started Window of the LV version it is associated with.
Bill
CLD
(Mid-Level minion.)
(2,179 Views)
