Reply
Can i get windows print dialog box in LabView? How?
Message 1 of 9
(2,237 Views)
Re: Can i get windows print dialog box in LabView? How?
hi
yes, you can (see attachment)
well, i'm sure tehre are several methods to show the dialog, e.g. WinAPI DLL-calls etc.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 9
(2,223 Views)
i tried doing your way, but it says "error -2147221230 occured at unknown system error in showprinter.vi"
on analysing i saw that, the refnum passes '0' as output to property as well as invoke node. suggest me the appropriate, either another way of doing it or rectifying(if needed) in the present solution.
Kinnary
Message 3 of 9
(2,209 Views)
hi,
well, there's a
PrintDlg in Comdlg32.dll, but that function needs a bad structure as input.
Visit
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/winui/winui/windowsuserinterface/userinput/commondialogboxlibrary/commondialogboxreference/commondialogboxfunctions/printdlg.asp
best regards
chris
Best regards
chris
Message 4 of 9
(2,194 Views)
Hi chris,
Got the dialog box by first mathod itself. now what shall i do next. mean how do i print a vi using the dialog box. what input shall i give to "printer name" in print report.vi (report generation toolkit). at present it uses default printer.
regards,
kinnary
Message 5 of 9
(2,187 Views)
hi
see attachment (as always, there are several solutions...)
best regards
chris
Best regards
chris
Message 6 of 9
(2,178 Views)
Hi Chris,
Both the solutions, show printer dialog box and printing of the vi, both are working fine individually. how do i co-ordinate both of them. mean i want the user to select the printer name from printers' dialog box. please suggest the soon.
Kinnary
Message 7 of 9
(2,157 Views)
Re: Can I get windows print dialog box in LabView? How?
Kinnary,
The example program titled Print Panel to Selectable Printer will allow you to first select a printer, and then print the front panel of the current VI. This example is designed to be used as a SubVI.
Scott Y.
NI
Message 8 of 9
(2,123 Views)
Please post the "Print Panel to Selectable Printer.vi".  The above link is broken. I need a vi like this.
Thanks.
Message 9 of 9
(896 Views)
