08-25-2015 12:38 PM
The hand drawn plot you posted looks like a polynomial or the sum of (1-exponential) functions.
There are many types of curve fitting available in LabVIEW, including fitting to custom functions. However, YOU must decide what knid of function provides a reasonable model for your process and your data.
Lynn
08-25-2015 12:43 PM
That's what i posted before:
1) ''The gas sensor gives the output in the form of Voltage and this voltage varies with the amount of specific gas particles present in the environment. Y axis is Voltage and x Axis is time. I gave previously a rough sketch and i am now attaching the image that contains a rough sketch of the output, i actually got from the person who has worked on it before.''
2) '' the data is coming from a gas sensor and its been done by someone else already the work i have got is to convert it to an envelope or a circular shape. and to do the corelation between the ideal circular shape and the one that i will get after converting my data to an envelope or a close enough circular shape''
08-25-2015 12:51 PM
It sounds like even you are not sure what the graph is supposed to represent... and that's NOT a LabVIEW problem...
08-25-2015 12:57 PM
This is my exact task:
'The gas sensor gives the output in the form of Voltage and this voltage varies with the amount of specific gas particles present in the environment that's why i can't get a value in the other quadrants. Y axis is Voltage and x Axis is time. The work i have got is to convert it to an envelope or a circular shape. and afterwards to do the corelation between the ideal circular shape and the one that i will get after converting my data to an envelope or a close enough circular shape''
08-25-2015 01:01 PM
I agree, it doesn't appear that you know what you want. You are describing a simple XY graph, I don't understand why you want to "convert" it to a circle. That isn't clear. And putting a circle around a group of points doesn't really tell you anything either.
08-25-2015 01:03 PM
Don't see how you can get a circular shape when time flows only in one direction. There's a piece of the puzzle that's plainly missing. You talk about converting your data into a circle. That's your job, not ours. Once you figure out that part, we can help you with the rest.
08-25-2015 01:06 PM
That's what my point was to my supervisor but he said he wants me to convert it to a circular shape even if it was a simple xy graph. and that's why i preferred to ask here as i did not understand how to convert this graph into a circular shape in Labview.
08-25-2015 01:08 PM
MY point is, it is NOT a LabVIEW issue. LabVIEW will plot what you want to plot. YOU have to decide what it is you want to plot first!
08-25-2015 01:09 PM
Ok I would ask him for further clarification. He's not explaining himself because it seems like something is missing. If your x axis and y axis are defined you can't just change where the points are to make a circle.
08-25-2015 01:10 PM
If the gas concentration varies sinusoidally with time (NOT what you have shown), you could separate the data into segments based on the period of the sine wave. Then each segment could be plotted parametrically as a circle. Other than that I see no way to even get close to a circle without much more information about the nature of your system.
Lynn
