10-22-2013 10:36 AM
Thank you mcduff!
04-05-2014 12:50 PM
I would also like to request your newest version saved for LabView 8.6 or before. I am using your original program but having trouble when trying to do sweeps with a SR844. Thanks for any help!
04-05-2014 01:21 PM
I do not have access to the source code at the moment, not until Monday at the earliest.
However, in regards to your question/problem, I never programmed/implented internal sweeps with the SR844, only with the SR850. You can either modify the program to do so, or you can use an external input to sweep your frequency.
mcduff
04-14-2014 04:53 PM
Dear mcduff, dear Andrew,
I used the program SRSFolder.zip 1289 KB but it seems the program does not run as it can not run the subVI Savetdms.vi properly (attached). Please suggest how to run it or select the proper path to the run the program. Thank you.
Mahmud.
04-15-2014 10:14 AM
What version of LabVIEW are you using?
Another option is to disable that part of the subdiagram and just do not save in TDMS format.
mcduff
04-15-2014 12:41 PM
I am using LabView 2010 SP1 (32 bit), however, my operating system is Windows 7, 64 bit..
I run the lockin amplifier (RS844) with a GPIB-USB interface and GPIB driver is from PROLOGIX (attached).
Any advice please.
04-15-2014 01:44 PM - edited 04-15-2014 01:50 PM
That error has nothing to do with the GPIB driver; it has to do with saving the file as a TDMS.
I reconverted the original to 2010 version; let me know if you stil have the error or not. When I open the file, I do not have an error. I am using 2013 though.
mcduff
Just looked up the Prologix USB to GPIB; see this thread
I do not have that hardware. It looks like you will have to do some modifications to the program in order for it to work correctly.
04-15-2014 03:26 PM
Hi, I run the version 2010Version.zip 2095 KB. but it seems to me attached files/vi are missing someway. Not sure how to get these missing files..
Thank you.
04-15-2014 03:32 PM
04-15-2014 07:01 PM
I have installed the JKI State machine software from the link. Good news is it solves one problem listed in my previous email. But still SubVI 'FileMaker9.vi is not executable.
Now, I am using RS232 (DCE) to USB port of the lockIn amplifier (RS844) instead port instead of the GPIB/USB adapter. But seems still the SubVI 'FileMaker9.vi is not executable someway.. ... More guide please.
