I would be really greatful if anyone could suggest a way to make my laptimer work.
I want to be able to reset that lap time when the lap button is pressed. Because of the loop structure i have i cannot pass the boolen trigger into the second while loop. Would an invoke node help? Im new to labview and so i dont really understand why this is not allowed.
you should be aware that LabVIEW has Dataflow, the inner while loop will read each iteration the data of the lap button as it was at the first time you should move the button insde the while loop together with the stop button.
Have a look at the attachement.
Ton
OR you could the whole way like devchander is showing.....
