08-28-2015 12:33 PM
Attached is the VI. This VI takes an enum (interpreted as a U16) and converts it to a single character. The inputs to this VI are sanitized so they do not have any out-of bounds conditions. This VI is used to uniquely name a log folder according to certain simulation characteristics. The extra characters in elements 5 and 21 are making my log/path VI's blow up (as there are extra newlines etc).
Solved! Go to Solution.
08-28-2015 12:37 PM
That's how you coded it up.
Do a size to Text on your array element. You actually have the extra Fs and newlines in there.
08-28-2015 12:37 PM
Change the display of your string array to 'Hex Display' or '\ Code Display' and you will quickly see what is going on.
08-28-2015 12:42 PM
08-28-2015 02:27 PM
@ijustlovemath wrote:
Aha! This has been the bane of my existence for the past few hours. The \ view is really helpful. Thanks!
And some advice with that, make sure the view mode is being displayed (right-click->Visible Items->Display Mode). It makes life easier since you then know which mode is being used.
