11-07-2014 02:40 AM
Solved! Go to Solution.
11-07-2014 03:01 AM
Hi Besho,
can't open your VI here, but I can suggest:
- use a picture ring with atleast two entries. Switch from one entry to the next after your "some time" delay.
- use a 2D picture indicator and draw your image in the indicator. After "some time" you erase the image in the indicator.
- use your image as decoration. Switch it's visibilty after "some time" using a property node.
11-07-2014 10:48 PM
hi dear,
i have tried to do it but i did't get the idea. i ve done the picture programming as shown in the picture attatched. But i am still wondering how am i going to make it appear and disappear
Thanks in advance
11-07-2014 11:04 PM
Try the attached. The visibility of the picture will be toggled by the boolean. Not sure exactly what you're trying to do, but you should be able to adapt the use of the property node to do what you need.
11-07-2014 11:53 PM
Thanks you very much, i got what i want :
