Can a LabVIEW executable be set to run as a system service?
Is there a relatively straightforward method to set a LabVIEW executable up as a system service, such that when Windows is started the executable will automatically be started as well.  Note, the LabVIEW program should be started without requiring a user to have logged in. (ie placing it in the startup folder is not sufficient)
If so, what limitations are there on the content of the executable?
(2,203 Views)
Take a look here:
http://zone.ni.com/devzone/cda/tut/p/id/3185
Matt
(2,200 Views)
