07-29-2014 11:31 PM
Hi all,
A customer has a large PC application developed with LabVIEW 2010 SP1.
They would like to add extend their system with a cRIO-9075. According to this document (ftp://ftp.ni.com/pub/devzone/tut/crio_software_versions.htm ), the minimum supported version of LabVIEW (with Scan Engine support) is LV 2011.
To minimize risks, it is preferred that we don't upgrade LabVIEW for the main application, which is atively being used in production.
I was thinking of developing the cRIO software in a newer version of LabVIEW (say, LV 2013 SP1), and using shared variables only to communicate between the PC and the cRIO.
Is this a viable option? Does it matter if the PC and the cRIO have different versions of the LV runtime?
07-30-2014 12:27 AM
It shouldn't matter, but then with shared variables you can never know for sure -- there are so many things that can make them break.
You might be money ahead to write the comm using TCP/IP. You know that will work.
Mike...
08-17-2014 08:45 PM
