08-12-2015 01:04 AM
I would like my application to check that all my required runtime licenses are installed when the program first runs. Is this possible? Specifically, I have servers that use a Volume License for Vision Builder AI 2013 SP1. Ocassionally the servers are unlicensed and I would like my application to inform the User that this is the case.
08-12-2015 09:13 AM - edited 08-12-2015 09:29 AM
You're going to need to access Reg keys in order to pull this information.
You can use the "Windows Registry Access VIs" palette to get at them. I would suggest browsing through regedit.exe to find the keys you care about and go from there using that palette.
Edit: Found this cool example. You need to change that first constant to reflect the license you want to check.
The key directory in the example uses "SOFTWARE\National Instruments\", but I found a lot more information on my computer at "SOFTWARE\Wow6432Node\National Instruments\". Just an FYI.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
08-12-2015 09:36 PM
James, Thanks. I can see there is a lot more information at "SOFTWARE\Wow6432Node\National Instruments\", particularly for Vision Builder. Oddly enough, one of my servers is not accepting a license from the Volume License server and yet the registry keys are filled in exactly the same as another server that is. So I can find no way to distinguish them. When I run Vision Builder on the server that is not showing licensed, it shows that it is running in the 30-day evaluation period. I searched the registry keys for a while between the two servers to see if I could find some way to distinguish them but I could not.
08-12-2015 11:12 PM
Cheers
