01-06-2006 10:37 AM
01-06-2006 10:51 AM
The cheapest way to control relays is to use the parallel port. Search for examples on the parallel port in Labview. If your relay draws too much current, you would have to build an interface to handle the current. Or you could buy a DIO that handles higher currents. Several high current DIOs are available. Search the web.
Measurement Computing makes a DIO that plugs into the USB port, and it comes with Labview drivers. It sells for about $100. NI makes a DIO that plugs into a PCI slot, it is also very cheap.
Example using a 5V relay that draws less current than DIO max current out: Wire one side of relay coil to ground. Wire other side to one of the DIO lines configured for output. Write Labview program to output TTL high on that line when you want to close the relay. If you want to synchronize the starting of another vi when the relay closes, use a double pole relay. Wire common contact on second pole to ground. Wire normally open contact to a DIO line configured for input. Write a Labview program that has a while loop. Inside while loop, read the DIO input. Should be high when relay is open. When you get a low, the relay has closed, exit the loop. After the loop, call the vi you want to start. There will be a very slight delay between the relay closure and the vi start (microseconds), but that is the only way to start a vi from a relay closure.
If using a relay greater than 5v, or the relay draws higher current than the DIO or parallel port can handle, you can use a ULN2003 IC to interface between the relay and port. Search web for ULN2003 to see specs and how it can work. I normally use a ULN2003 along with an inverter, tie one end of relay coil to 5v/12v/24v (whatever is needed), tie other end to output of ULN2003. Wire DIO output to inverter, and inverter output to ULN2003 input. When DIO output goes high, relay turns on. This helps keep the positive logic flow, hi means on, low means off.
01-06-2006 10:58 AM
Hi tbob,
Very nice description.
Bonne Annee l' cousin!! 😄
01-06-2006 11:10 AM
01-06-2006 03:39 PM
