12-19-2014 10:02 PM
When I try to use report vi to print QR barcode through Zebra s4m printer, the barcode will become to rectangle not square as expected.
If I use a laser printer, the barcode keeps in square. If any one can help me with this problem?
Thanks a lot!
12-20-2014 04:32 PM
This (probably) has to do with the way your Bar Code Printer interprets the data produced by LabVIEW. Are you creating an HTML document or some other format? I suspect that you'll need to get help from Zebra for this.
BS
12-26-2014 08:58 AM
Thanks!
I have found that the problem can be fixed by setting the page size of the printer.
