Can I run or duplicate a photoshop process (filter->distort->displace) in labview?
I am trying to project an image onto an uneven surface. I have a depthmap of the surface and want to distort the projected image to match the uneven surface. I beleive I can achive this using photoshop's displacement map filter. Is there a way I can run that process in labview?
link shows the displace filter effect:
http://photoshopcafe.com/tutorials/dispmap/dispmap.htm
Thanks.
(2,479 Views)
i have found a link, which might be interesting for you:
http://docs.gimp.org/en/plug-in-displace.html
it has the formulas for the displacement filter, so i guess by having a picture in labview, using the formulas you can perform the filter by using array operations
__________________
Engage! using LV2015
(2,465 Views)
