12-16-2015 08:38 AM
I don't know if I can describethat very well (I am learing LabView at the moment)
Is it possible to "move" the user specific Add ins?
So that they not appear in "right click > User Libarys > Add in" but in "right click > Add in"?
I am Using LV 2011 and 2014 both 32bit and 64bit Versions and Windows 7 Prof. 64 bit.
12-16-2015 08:55 AM
Tools->Advanced->Edit Palette Set.
I don't normally suggest moving things around in the palettes. Just be careful.
12-16-2015 08:57 AM
12-16-2015 09:03 AM
usually I would agree, but it is for a test for my company to get our VIs faster, would it be possible to just "copy" the tool or create a link?
12-16-2015 10:09 AM
We put all of our re-use libraries into VI Packages - with those we can specify exactly where the VIs appear in the palette menus (including icon/position/ordering). Maybe it would be worth looking at?
12-24-2015 02:18 AM
I solved the problem, I just add them manually in, and not drag n drop them in the user.lib .
The solution (from an earlyer message was correct) is like that: Tools -> Advanced -> Edit palette Set -> then on the Palette right click -> insert -> (the wanted VIs)
