Can I detect if a module is present in CRIO FPGA?
The 9082 cRIO is running RT 2014 and I am developming on LV 2014.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 11 of 15
(718 Views)
Hello James,
Which version of DAQmx are you using?
Collin D.
Software Product Manager
Message 12 of 15
(689 Views)
I'm running DAQmx 14.0.0.
Why are you asking about DAQmx? From what I understand, cRIO's don't support DAQmx, only cDAQs.
Cheers
Message 13 of 15
(676 Views)
Hello James,
I would follow Doug's recommendations in the other thread and call in to Applications Engineering to get assistance with your issue.
Collin D.
Message 14 of 15
(655 Views)
Some RIOs support DAQmx as well.  It's certainly not only cDAQs.  cDAQs are a subset of the DAQ devices.
Have you tried reformatting the cRIO?  It's a trivial task and sometimes clears up issues.
Message 15 of 15
(646 Views)
