Hi Biberkacke,
just right-click the property nodes. The first menu entry is 'set all to write' (or 'read'). You can also set single properties to read/write, when you use more than one property in a node.
In read mode you get the actual settings. To chnage settings you have to switch to write mode!
What did I do:
I cleaned up your code a little bit. Then I added a property node for the Histogramm. Then I added a while loop to demonstrate the new behaviour...
Now you can change lin/log mode to see the difference. Use the stop button to stop the vi.
Message Edited by GerdW on 12-12-2006 10:45 AM
