09-30-2014 11:22 AM
Sorry, it looks like those menus are from LabView or something....which I do not have.
Doesn't look like a link from this NI website.
I don't know how you got the menu with mathematics..
09-30-2014 11:23 AM
Yes, of course they're from LabVIEW, you posted in a LabVIEW forum! If your question wasn't about LabVIEW, then why are you posting here?
09-30-2014 11:31 AM
Sorry
tried to be clear about using a Fluke 54 thermometer.
My readings came out from 22°C to 90°C using a K thermocouple with the input set for J type.
Thanks for your quick help! Hoped someone could help in this regard. Didn't think it was LabView specific.
09-30-2014 11:35 AM
Well, the constants and equations you need to do the calculations yourself are all available online, for example from http://www.omega.com/temperature/Z/pdf/z198-201.pdf
09-30-2014 11:40 AM
Thanks Nathan!
10-06-2014 05:11 AM
Hi
i collected temperature data by using agilent measurement for temperature after that i noticed the thermocouple is J type but i measured it in K type(Manual Setting configaration). and now i need to convert Ktype data to J type data...how does it can be possilbe plz... give me a suggestion
10-06-2014 05:12 AM
Hi
10-06-2014 05:36 AM
Ok, just to be sure, you are using LabVIEW, do you? If so you will simply have to go through this thread and follow Nathan's explanation. If not you will have to dig into the polynomial tables those VIs are based on and which come from NIST and calculate in the tool of your choice (or by hand) the temperature to voltage conversion for your measurements and original thermocouple type and then from there back to temperatures using the new thermocouple type.
10-15-2015 08:43 AM
